DanielO77's avatar
DanielO77
Follower
Jan 13, 2024
GS605 Ethernet cord goes in and out light will be solid then goes out
I’m plugging my pc Ethernet into the GS605 and it’s not fully connecting it will kind of work then go out with the light being solid then seconds later it going out and flashing tried 2 different Ethernet cords
1 Reply
  • FURRYe38's avatar
    Try a different device connected to the switch to see if same thing happens?
    What is the brand and model of the ethernet adapter in the PC?
    Be sure drivers are up to date for the ethernet adapter in the PC from the ethernet mfr.
    Check the user manual for LED behaviors.
    CAT6 UTP cabling is recommended.
ProSupport for Business
