johnatMSP
Jul 28, 2023Aspirant
GS716 series
All versions of the GS716 seem to be "end of life." Yet Amazon has some in the rice rannge I need with two F/O ports Does anyone know the difference between the following versions? GS716TP GS716T...
- Jul 28, 2023
The GS716TP and TPP 16-port Gigabit Ethernet PoE+ Smart Switch with 2 SFP Ports and Cloud Management switches, with a total PoE power budget of 180W (GS716TP) or 300W (GS716TPP). The GS716Tv3 is a non-PoE switch GS716Tv3 16-port 1000base-T Gigabit Smart Switch version.
johnatMSP
Jul 31, 2023Aspirant
Thank you,
When did the GS716 series reach end of life?
schumaku
Jul 31, 2023Guru - Experienced User
This is about the window to what you might understand as the GS716T Series. Depending on the market, many of these models remain available in the field, the retail or distribution channel. Note: Don't be confused with an End-of-service date, where NETGEAR discontinues support and maintenance firmware releases, including security updates. This would be several years later.
