stones2k
Feb 04, 2026Tutor
GS716T-300EUS
hi, just purchased GS716T-300EUS model please, can anyone send link to support and firmware pages with datasheet and manual for this model or its too outdated?
stones2k
Feb 04, 2026Tutor
thanks, i searched by full name GS716T-300EUS, but didnt found.
so the GS716Tv3 is exactly GS716T-300EUS model.
Feb 04, 2026Guru - Experienced User
Where are you seeing this -300EUS on the unit?
I tend to look at the front of a the unit for exact printed model #. My unit shows a GS728TXv3. The -300EUS tends to be just a marketing regional SKU number on the sticker in back or under the unit for retail stores and such.
- StephenBFeb 04, 2026Guru - Experienced User
No idea on location of the label stones2k is seeing, but the -300xxx suffix does identify it as a v3. You can see that convention on the datasheet here (pages 12 and 13): The xxx bit identifies the region.
- https://www.downloads.netgear.com/files/GDC/datasheet/en/GS716Tv3-GS724Tv4-GS748Tv5.pdf
ReadyNAS products used the same convention.
