ricardoacosta
May 31, 2022Aspirant
GS724TP connection over GLX-SX-MMD SFP to CISCO 3560-X
I’m trying to connect my new GS724TP over MM fiber using a Network Hardware Resale (NHR) GLC-SX-MMD SFP module to my existing Cisco 3560-X switch… should it work? any tips? thanks
DaneA
Jun 01, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
It may or may not work. Be informed that NETGEAR recommends to use the compatible SFP module for the GS724TP which are the following listed below:
AGM731F 1000BASE-SX SFP Module
AGM732F 1000BASE-LX SFP Module
AGM733 1000BASE-LZ SFP Module
As reference, kindly check the GS724TP data sheet here.
DaneA
NETGEAR Community Team
