ParmarH's avatar
ParmarH
Follower
Mar 22, 2024
GS724TP STP Configratioan
I have GS724tp and GS728TPP and XSM4316S switch ..
XSM4316S is Layer 3 switch But when I'm close ring topology GS724tp is Being Root switch
1 Reply
  • schumaku's avatar
    schumaku
    Are you operating STP or RSTP (valid for the complete network), or MSTP (individually on each VLAN configured and active)? Either way, the lower the priority, the greater greater chance of becoming the root. When I have it right, Netgear does define the STP priority (misleadingly named "Configuration Revision Level") to the default 32768 when I have it right. You can adjust in steps (increments or decrements) of 4096.
ProSupport for Business
