wardh_2021
Feb 20, 2023Follower
GS724Tv3 — 24-Port Gigabit Ethernet Smart Switch with 2 SFP Ports - cable testing
Hi,
I have the following type of swtich which I want to install:
https://www.netgear.com/support/product/GS724Tv3
If I put this on my network does it have the facility to identify faulty cables.
I am trying to identify a problem with dropouts and I have 2 unmanaged switches.
I am not sure if it is cables at this stage or a faulty switch.
If I replace one of the unmanaged ones to it looks like this
At the internet side my router kept working via Wifi but the ethernet failed.
Before:
<PC> --> <Unmanaged Switch> -- <Unmanaged Switch> -- <Internet>
After
<PC> --> <Unmanaged Switch> -- <GS724Tv3 > -- <Internet>
Now with the after configuration (as that is switch I suspect is faulty).
With this smart switch can it help me identify the problem if it is due to a bad cables etc.
And what type of logs would I be looking at in this switch?
Thanks
Ward
No RepliesBe the first to reply
