sc101hell
May 21, 2020Tutor
GS724Tv3 Orange Power light only - won't boot after firmware update
Hi all, In theory this should have dual firmware to prevent this happening but 30+ seconds of holding rest (with everything unplugged) isn't kicking it into life so thought I'd see if anyone here ...
- May 25, 2020
Maybe I'm wrong but I thought that this switch has dual firmware to prevent this happening?
I was therefore trying to ask the community if they know a way to switch to the other firmware/ any way to reset this please? Can you help with advice as seems a real shame that this is bricked when it could be useful?The GS724Tv3 supports Dual Image. One image is the active image, and the second image is the backup image. As reference, kindly read pages 261-263 of the GS724Tv3 Software Administration Manual here.
Not sure if this will help. Let me share the old forum thread here. Read the solution posted by -c0de- and you can follow the steps he did at your own risk.
DaneA
NETGEAR Community Team
DaneA
May 24, 2020NETGEAR Employee Retired
Found out that your case # 42680895 was already set to close status. Since your GS724Tv3 is a second hand device, a replacement cannot be processed.
DaneA
sc101hell
May 24, 2020Tutor
Hi Dane,
Thanks, I completely understand not supporting the device. Just to clarify it's new/ unused but given as a donation but yes, we're not the original purchasers, so no support. All good there (actually you'll see 2nd line looked like they were going to help before the slightly strange last answer closing the call but fair enough).
