Knyix
Sep 20, 2019Tutor
GS724Tv3 VLan tagging issues
Hello all!, Forgive me if I misformat this a bit as I am new to the forum Recently I came into owning a Netgear Prosafe GS724Tv3 and I am planning on using it as the core switch for my virtualiz...
- Sep 21, 2019
I found the issue!,
luckily when I was diagnosing the vSwitch as you mentioned I seem to have come accross the problem being,
and do I feel very dumb for not realizing this sooner, I had the two cables connecting the ESXi in the opposite ports,
so the correctly tagged VLAN 10 traffic was allowing me to manage the ESXi and the PVID with an untagged port was not allowing me to tag my own VLAN traffic.
I was able to test this and verify it is all functioning as intended,
thank you for all the help and I appriciate you taking your time on my problem!
and I am sorry it was such a small issue!
schumaku
Sep 21, 2019Guru - Experienced User
If you want to support multipe VLAN on a vSwitch in VST mode, there must be tagging - except for the default VLAN 0 and 4095. https://kb.vmware.com/s/article/1004074
Knyix
Sep 21, 2019Tutor
I found the issue!,
- schumakuSep 22, 2019Guru - Experienced User
Hey no problem! There are always the small nifty details... Happy your set-up is up and running now.
