samarthengineer
Apr 24, 2025Aspirant
GS724Tv6 and Use of STP
Hello, In a network scenario, we have total 5 Netgear switches. We have 2 GS724Tv6 switches and 3 GS724TPv3 switches. Check the topology below: When we implemented this design, I found that on...
- Apr 24, 2025
Taking control of STP (resp the preferred RSTP) is the key here, and not leaving the switches on the default priority.
DSW-1: 4096
DSW-2: 8192
PSW-1: 40860
PSW-2: 44965
PSW-3: 49052
Does that load balancer participate in STP/RSTP? If yes, enable and configure it accordingly:
LB: 4096
DSW-1: 8192
DSW-2: 12288
PSW-1: 40860
PSW-2: 44965
PSW-3: 49052
schumaku
May 13, 2025Guru - Experienced User
A more sophisticated approach would be to set the switches in the same "level" to the same priority, like
LB: 4096
DSW-1: 8192
DSW-2: 8192
PSW-1: 12228
PSW-2: 12228
PSW-3: 12228
