BobC99
Apr 06, 2019Tutor
GS748TP where is boot code version 1.0.0.5
I have an GS748TP with version V1.0.0.22 software works good, that I want to upgrade to latest software version. The instructions for the upgrade indicate that I need to first upgrade to boot code 1....
- Apr 07, 2019
Hi BobC99,
Where can I get boot code 1.0.0.5. I do not see it on the netgear website.
Kindly download firmware v5.0.0.14 then unzip it and you will get the boot code v1.0.0.5 as well as the GS700TP_V1.0.0.inter.ros.
The instructions also say I must interim image (GS700TP_V1.0.0.inter.ros) first.
Which one do I do first the boot code or the image file???
I have an GS748TP with version V1.0.0.22 software works good, that I want to upgrade to latest software version. The instructions for the upgrade indicate that I need to first upgrade to boot code 1.0.0.5, currently installed is 1.0.0.4.
Since you mentioned that your GS748TP is on v1.0.0.22, then you need to upgrade the switch to the interim image first (GS700TP_V1.0.0.inter.ros). Then, perform the upgrade again from the interim image to V3.0.6.1.
The procedure for upgrading the device to the interim image is the same as the regular firmware upgrade.
DaneA
NETGEAR Community Team
DaneA
Apr 07, 2019NETGEAR Employee Retired
Hi BobC99,
DaneA
- BobC99Apr 07, 2019Tutor
Thanks, this upgrade worked perfectly. I Love Netgear products!
