LukasO
Oct 27, 2021Aspirant
GS750E WebInterface does not load after update to 1.0.1.10
Hi Community, anyone else having issues with the WebInterface being stuck at the "login" screen after updateing to version 1.0.1.10 ? Both my GS750E do not load the webinterface after typing in the...
schumaku
Oct 28, 2021Guru - Experienced User
Instead if the "Enter" key as we're used to, please try to click the [Login] button.
- LukasOOct 28, 2021Aspirant
Unfortuntelly,
no. It is not that easy. After clicking on "login" (with the correct password) the browser does POST requests ~ every second to:
"set.cgi?cmd=home_loginStatus&dummy=<EPOCH Timestamp>"
But the website does not change, stays on the login screen.
Verified same behaviour with latest MS Edge Browser.
- schumakuOct 28, 2021Guru - Experienced User
LukasO wrote:
Unfortuntelly, no. It is not that easy.
FF 93.0 - but I admit on Win10-64 - works for login to GS750E v1.0.1.10, levaing alone some bunches (and more CSS) of messages on the console.
The workaround I've shown is required on certain models/firmware since they added some security quirks and is required for Chrome, Edge, ....and comes from a different model in fact, but it's the same here on the GS750E as a "side effect" of the security fixes.
Appears there are more e.g. on the LTS Firefox on [Linux? MacOS? ...] .... YeZ
Almost the same here Win-10 64, with (almost) latest patch level and FF 75 or latest Edge and now ProSafe.
Mostly Linux with FF 78 ESR.
FF Devconsole gives me:
TypeError: document.forms[0].err_flag is undefined login.html:99:7 CheckError http://<IP>/login.html?ver=1635420486921:99 success http://<IP>/login.html?ver=1635420486921:221 success Backbone jQuery 4 i fireWith y cright at loading of the login page.
Edge reports:
Uncaught TypeError: Cannot read properties of undefined (reading 'value') at CheckError (login.html?ver=1635420831934:99) at success (login.html?ver=1635420831934:221) at Object.t.success (backbone-1.0.0.min.js:1) at i (jquery-1.12.4.min.js:2) at Object.fireWith [as resolveWith] (jquery-1.12.4.min.js:2) at y (jquery-1.12.4.min.js:4) at XMLHttpRequest.c (jquery-1.12.4.min.js:4)Both switches show the same error.
My management system and the switches are offline, not connected to public internet.
Could the be a hint?
- May 25, 2022Retired_Member
