Tripo
Jun 06, 2020Tutor
GS752TPv2 and DHCP
Hello all, I hope somebody could help me with my problem. I recently got a GS752TPv2 and I am trying to make it work properly with my DHCP. Here is my installation right now for testing: Inte...
- Jun 08, 2020
I am replying to myself because Netgear's technical support found the solution. Without really understanding why, it seems my router was creating a loop. I deactivated STP and now everything works perfectly so if somebody also has an issue getting an IP using DHCP, try deactivating STP!
schumaku
Jun 06, 2020Guru - Experienced User
By default, these switches are L2 devices spanning a transparent LAN. If neither the switch itself nor a connected computer does get a IP address assigned, the first guess is that the network connection from the router to the switch isn't up, or (unlikely as you stated the same issue happens following a switch factory reset) there are multiple VLANs configured for the management, and for the ports used for the link to the router and the computer.
Tripo
Jun 06, 2020Tutor
That's exactly my problem, the switch should be transparent and gets an IP from my DHCP but it doesn't, even after the factory reset. I am using nominal configuration (no VLAN, nothing set up) and it doesn't work. I really don't understand. Is there a way for me to run a diagnostic on the switch? I just bought so I don't think the problem comes from the switch itself but (if I'm really unlucky) it might...
