ThomasH12345
Oct 11, 2024Aspirant
GS752TPv2 and GS724TPv2 dont 802.1x authenticate some wpa_supplicant clients
Hi,
i'm operating GS752TPv2 and GS724TPv2 and other managed switches. I have started to implement 802.1x port authentication, which generally works very well.
I have some problems with some wireless access points, running openwrt though:
AVM Fritz!repeater1200
GL.inet AR300M
Zyxel NWA50AXPro
All of them run openwrt, wpad-mbedtls and are configured identically regarding 802.1x authentication using wpa_supplicant.
All three AP authenticate well on Zyxel switches.
The GL.inet also authenticates on the netgear GS switches.
Both Fritz and NWA50AXPro authenticate on Zyxel switches but not on the netgear GS switches!
The log on the GS752TPv2 shows this:
| <181>1 2024-10-11T12:55:59.364+02:00 10.250.0.250-1 AUTHMGR-5-LOCK proto_authmgr_action.c(757) %% Client (MAC REDACTED) is locked on interface GigabitEthernet26 SessionID 0000005D7B3824D0 |
| <181>1 2024-10-11T12:55:59.354+02:00 10.250.0.250-1 AUTHMGR-5-FAIL proto_dot1x_sm_pae.c(195) %% Authentication failed for client (MAC REDACTED) on interface GigabitEthernet26 SessionID 0000005D7B3824D0 |
| <183>1 2024-10-11T12:55:59.354+02:00 10.250.0.250-1 AUTHMGR-7-NOMORE_METHODS proto_dot1x_sm_pae.c(184) %% Exhausted all authentication methods for client (MAC REDACTED) on interface GigabitEthernet26 SessionID 0000005D7B3824D0 |
<181>1 2024-10-11T12:55:59.354+02:00 10.250.0.250-1 AUTHMGR-5-DOT1X_FAIL proto_dot1x_sm_pae.c(163) %% Authentication failed for client (MAC REDACTED) on interface GigabitEthernet26
The Radius Server is not contacted in this case.
Any ideas what the cause might be? Anything to check?
Thanks for Reading
TH
Alright,
i'm answering myself. The solution is to associate the lan interface with the eth-device directly instead of via a brigde device (in openwrt).
- ThomasH12345Aspirant
Alright,
- BrianLNETGEAR Moderator
Hi ThomasH12345,
Welcome to the community!
Thanks for submitting this query and for sharing what fixed it.
Kind regards,
BrianL
