creiss
Jun 01, 2020Guide
GS752TPv2 Annoyances
Hello Community, Hello Netgear, I just now received a GS752TPv2 52 Port POE Switch. Up to today I -on work- deployed a lot of those and smaller sibblings across a host of DataCenters and Customers....
- Retired_MemberJun 04, 2020
Could you please upgrade to latest firmware v6.0.4.6 and try again? There is one button 'Don't remind again' on the popup notice window, please select this box and click OK button. Then this screen will not popup when you login next time, but it will popup again if you do factory default.
Retired_Member
Jun 01, 2020Hi creiss ,
Welcome to Community!
If you don't want to manage switch with Cloud mode or your device doesn't access to Internet. I suggest you go to my.netgear.com website, register and get the 'Registration key' of your switch. Then you can input the 'Registration key' on switch web GUI even it's not online.
If you active 'Registration key' on your device, it will never popup nag screen until you click 'Reset and erase everything including registered device status' button on 'Maintenance->Reset->Default Setting' page.
Hope it helps!
Eric
creiss
Jun 03, 2020Guide
Hey EricZ!
Thanks for taking the time to reply, likewise sorry for me taking the long time to reply. Life is upside down at the moment here.
I did a factory reset of the switch (including reg data) as well as entering the reg-key from my.netgear.com as well as blocking any and all traffic from the switch to the internet: The
This device is currently set to be managed through the local browser interface from the local LAN connection only. You can activate the Insight Cloud Management, which allows you to manage the device through the NETGEAR Insight mobile app or Insight Cloud Portal, by changing the management mode to NETGEAR Insight Mobile App and Insight Cloud Portal (Cloud/Remote). To use remote/cloud monitoring and management, you need to create a NETGEAR account, if you have not yet done so, and subscribe to the Insight service. Details about Insight and its benefits, features, and pricing can be found at https://insight.netgear.com. Note: Switching from Local-only management to Insight management will reset the device to factory defaults so that the new configuration and network topology can be created from the Insight Cloud. Once you have enabled the cloud/remote management from Insight, the local browser interface will be disabled and should then only be used for advanced debugging or for non-Insight-manageable settings changes. To see a list of the Insight-manageable device settings, click here.
Nag screen refuses to go away.
