creiss
Jun 01, 2020Guide
GS752TPv2 Annoyances
Hello Community, Hello Netgear, I just now received a GS752TPv2 52 Port POE Switch. Up to today I -on work- deployed a lot of those and smaller sibblings across a host of DataCenters and Customers....
- Retired_MemberJun 04, 2020
Could you please upgrade to latest firmware v6.0.4.6 and try again? There is one button 'Don't remind again' on the popup notice window, please select this box and click OK button. Then this screen will not popup when you login next time, but it will popup again if you do factory default.
creiss
Jun 03, 2020Guide
Hey Ericz!
Thanks for replying. For some odd reason, my reply vanished. What I wrote was: Despite factory resetting, blocking the switch on the firewall, getting the registration key the nag screen still pops up. But its good to know that even a factory reset does not wipe the registration status.
That nag screen really is annyoing. How to turn it off?
At least its solved by 50%.
I did a downgrade to Version 6.0.0.48 and the nag screen dissapeared. It seems to appear with 6.0.1.x and higher.
Retired_Member
Jun 03, 2020
Yes, it's a basic change from v6.0.1.4, you can check the detailed info in the release note.
For factory default, there is two button for user selection.
First one: Only reset the configuration but not erase registered info;
Second one: Erase both configuration and registered info;
So if you don't want to erase registered info(mean not hope switch popup registered page again even when do factory default), please select the first one button.
By the way, if you press the front plane 'Reset' button more than 10s, it will do factory default and erase all information include registered info.
