creiss
Jun 01, 2020Guide
GS752TPv2 Annoyances
Hello Community, Hello Netgear, I just now received a GS752TPv2 52 Port POE Switch. Up to today I -on work- deployed a lot of those and smaller sibblings across a host of DataCenters and Customers....
- Retired_MemberJun 04, 2020
Could you please upgrade to latest firmware v6.0.4.6 and try again? There is one button 'Don't remind again' on the popup notice window, please select this box and click OK button. Then this screen will not popup when you login next time, but it will popup again if you do factory default.
creiss
Jun 04, 2020Guide
Hey,
thanks for replying. There are two issues with my switch:
1. The activation code (solved)
2. The nag screen (I am currently set to local etc, see my picture in my original post). This does not go away.
For 1. you are right and this issue is gone.
Retired_Member
Jun 04, 2020
- creissJun 05, 2020Guide
Hey,
that solved all issues. The nag screen did not reappear again. Much appreciated! (I was sure the nag screen was still there and I did flash the latest firmware in the past).
