creiss
Jun 01, 2020Guide
GS752TPv2 Annoyances
Hello Community, Hello Netgear, I just now received a GS752TPv2 52 Port POE Switch. Up to today I -on work- deployed a lot of those and smaller sibblings across a host of DataCenters and Customers....
- Retired_MemberJun 04, 2020
Could you please upgrade to latest firmware v6.0.4.6 and try again? There is one button 'Don't remind again' on the popup notice window, please select this box and click OK button. Then this screen will not popup when you login next time, but it will popup again if you do factory default.
Retired_Member
Jun 04, 2020
creiss
Jun 05, 2020Guide
Hey,
that solved all issues. The nag screen did not reappear again. Much appreciated! (I was sure the nag screen was still there and I did flash the latest firmware in the past).
