sistematico_17
Jul 19, 2022Aspirant
GS752TPV2 voice and data on same port
Hello, I've tried every possible combination of tagged, untagged, and PVID and can't get the voice and data to work over the same port. My voice and data are on the same VLAN 1. Is a small of...
schumaku
Jul 23, 2022Guru - Experienced User
Voice and data is on the same VLAN 1, so it's the same network, same everything, isn't it? You need to avoid the OID does put in place OID specific VLAN (like Voice).
sistematico_17
Jul 28, 2022Aspirant
Yes, Voice and data are on the same VLAN 1. However, for this one specific port, I need to connect a Phone that uses VLAN 1 and a Cameras that uses VLAN 30.
What changes do i need to make to get that working? Thanks
- schumakuJul 29, 2022Guru - Experienced User
What does stop you? Keep the VLAN 1 config, just add the VLAN 30 tagged, configure the camera LAN 30 tagged. And then the other areas of the switch and network where you need to carry this VLAN 30 of course.
- sistematico_17Aug 03, 2022Aspirant
Thank you but what you suggested did not work
- schumakuAug 03, 2022Guru - Experienced User
And what does not work?
The simple untagged VLAN 1 with an untagged device? You might look into disabling the Auto-VLAN config on this specific port in case.
The camera configured for VLAN 30 tagged on the port configured for VLAN 30 tagged?
