tommymaguire
Nov 01, 2021Aspirant
GS752TXS device view
Hi, has anyone managed to solve the device view issue with these switches, its a bit of a minefield. If there is no direct resolution does anyone have a workaround, thanks
tommymaguire
Nov 02, 2021Aspirant
I had already upgraded it to firmware (v6.1.0.39), people seemed to indicate its a java issue, is this correct?
Thanks
schumaku
Nov 02, 2021Guru - Experienced User
Several older switches Web UI are not updated towards a HTML5 device view - the Java based one is inop, the the Applet API should be drpreciated for removal. It is essentially irrelevant since all web-browser vendors have either removed support for Java browser plug-ins.
