ChristopherG
May 20, 2021Aspirant
GS752TXS VLAN Trunk (to M4300)
Hello, i recentrly bought a M4300(M4300-12X12F) + this GS752TXS Switch. Now i figured out that i have no trunk option on the gs7 one. How should i configure the trunk? Trunk mode on the m4300 a...
- May 21, 2021
Welcome to our community! :)
Setting up a trunk on NETGEAR switches is the same as T or Tagged. If you are going to connect a trunk port to this NETGEAR switch, the port should be assigned as T or Tagged and then assigned the native VLAN on the PVID configuration.
John
NETGEAR Community Team
JohnC_V
May 21, 2021NETGEAR Employee Retired
John
