SidHarberbridge
May 29, 2024Aspirant
help choosing best switch for home
Hi, I could use some help trying to find the correct forum here. Trying to find a home switch with 16 ports, PoE+, and lowest possible energy consumption. Needs to be managed via Utility or W...
schumaku
May 29, 2024Guru - Experienced User
Whatever green Ethernet credentials are.
Talking about Energy Efficient Ethernet probably? In the standardization, this has the designation IEEE 802.3az, and is.in place since the year 2010.
SidHarberbridge
May 30, 2024Aspirant
It would seem 'Green Ethernet' is a marketing term worthy of condescension by some. But yes, EEE.
Perhaps I should rephrase the question:
Does Netgear make a home switch with 16 ports, PoE+, and lower energy consumption than competitors (e.g. Tp-Link Easy Smart TL-SG1218MPE)?
I really need to speak to Netgear sales but they're impossible to reach.
I'm using the Netgear AV range at work but don't need that level of sophistication for home switch. Help would be greatly appreciated. Thanks.
- schumakuMay 30, 2024Guru - Experienced User
16 fully useable PoE+ ports does translate to 16 times 30 W == max. 480 W PSE, 30 W at the power source equipment (PSE), plus what the pure switch core does pull, plus what the SFP or SFP+ modules require ... with some 500 W you should come handy and the full power budget available.
Not sure what you expect from Netgear sales - a 0.5 KW switch operating on peanuts? Nothing "green" here in reality.
As you insist on 16 ports, the selection is limited to unmanaged PoE+ models only.
Power usage is not related to any "green" magic, much more it depends on the PoE+ power the switches can supply overall.
https://www.netgear.com/business/solutions/poe/devices/ does show at least four different (tough very similar) 16 port GbE unmanaged switches
Lifetime Warranty, plus lifetime online support and lifetime Next Business Day (NBD) replacement.
- GS116LP (total 76 W power budget for all PoE/PoE+ power delivery ports)
- GS116PP (total 183 W power budget for all PoE/PoE+ power delivery ports)
https://www.downloads.netgear.com/files/GDC/GS108PP/GS108LP_GS108PP_GS116LP_GS116PP_DS.pdf
3 Year Warranty (excluding for China), 2 years on the power supply
GS316P (total 115 W power budget for all PoE power delivery ports)- GS316PP (total 183 W power budget for all PoE/PoE+ power delivery ports)
For reference, here all currently available PoE switches
- SidHarberbridgeMay 30, 2024Aspirant
thanks Schumaker,
Of course the PoE+ current draw depends upon what's hooked up to it, and that applies equally to all brands. But I do like the interchangeable external power adapters on some of the Netgear products.
What makes a difference in kWh over a 5-10yr lifespan is how much the 'pure switch core' pulls. And that's proving difficult to discern. I suppose the data sheet gives 'Min power (link-down standby) (Watts)' as a useful reference point. But short of purchasing one and baking it off against a comparison unit on the bench on power meters, it's probably not possible to determine 'lowest possible energy consumption'.
PS Banging on about "green," peanuts, and magic is getting a little churlish, but I'm guessing that's your "style"? Consistent, at least. Keep it up!
