Jcereijo
Apr 30, 2021Initiate
Home Network Setup Help- ATT Fiber to Prosafe Plus Switch
I need help with how to properly setup my home wire/wireless. Over the last couple of years, we have added more and more devices to the network and Im not very IT savy so Im pretty sure the way I hav...
DaneA
Jun 03, 2021NETGEAR Employee Retired
Welcome to the community! :)
As I have checked the attached image, it seems you need to implement VLANs in order to separate your home/office network from guests. The GS108PE supports VLAN however we need a router that also supports VLAN. Does your AT&T BGW210 router supports VLANs?
DaneA
NETGEAR Community Team
Jcereijo
Jun 03, 2021Initiate
Thank you. I actually have Guests setup through the At&T router. Seem to be working well.
As I didn’t get any responses when I originally posted this, I spent some time through the forum and made some changes. I have the sound bars and any low data equipment using WiFi and the higher bandwidth electronics such as TVs hardwired through the Netgear Switches. I also decided to go with adding a Nighthawk X4 used in Repeater mode. I installed it in the farthest part of the house near the living room, master bedroom and patio area and it seems to have fixed all my issues.
This community forum has been great for learning. Thanks for responding!
