dward_support
Oct 12, 2021Aspirant
How can I hide the switches from appearing in Network Neighborhood?
Hi everyone, first post here I have a dozen or so managed switches, mostly model GS752TPv2, and my question is whether there is a way to hide them from appearing in Network Neighborhood on our Win...
- Oct 13, 2021
Hi,
Absolutely normal - the in-line images are under mandatory moderation. Unfortunately, the SaaS does not indicate this.
To my knowledge, there is no control on the Web UI (as of writing, and different from the simple Web configurable Plus switches) to disable the UPnP SSDP announcement, as well as the NDST one.
With your network size, I would suggest to maintain a dedicated management VLAN - not "just" because of the discovery, also for good management and security behaviour.
-Kurt
dward_support
my screenshot isn't uploading, I only see a yellow triangle, so I am attempting to retry
- schumakuOct 13, 2021Guru - Experienced User
Hi,
-Kurt
