ies-ny
Jan 14, 2021Aspirant
Insight managed switch port showing "Blocked"
We have a GC752X that has a port that shows up as "Blocked" in the Insight portal. We cannot figure out how to change this status or even what this status entails. It seems like traffic through that ...
schumaku
Jan 14, 2021Guru - Experienced User
Consulting the logs might show it ws a DoS event shutting the port down. What is connected to the port 50?
ies-ny
Port 50 is a fiber connection to another switch in the network. If the logs do suggest a DoS issue where would be have to go to resolve that.
- schumakuJan 14, 2021Guru - Experienced User
The problem might be that the generic DoS log isn't informative enough to isolate the real cause. Re-enable the port, and see if the issue does come back.
Vote up here -> Idea Exchange for Busness: DoS detailled log informtion on Smart Managed Pro switches including the cloud managed units
