guido79
Aug 25, 2020Tutor
JGS524Ev2 - Have to keep rebooting switch to get IP working again
I've been using my switch with firmware v. 2.6.0.43 and I'm noticing that after some random period of time, all traffic will go deaf on the switch and all of my devices connected via ethernet will re...
- Aug 25, 2020
DaneA wrote:Let us try this. Perform a factory reset on the JGS524Ev2 then reconfigure the settings from scratch. Be sure to set a static IP address on the JGS524Ev2 that is within the IP address range of your existing network. Observe if the same problem will occur.
DaneA
NETGEAR Community Team
Thanks DaneA . I will give this a go to see what happens. I'm now using a static IP for the switch on my network. 🤞🏻
DaneA
Aug 25, 2020NETGEAR Employee Retired
DaneA
- guido79Aug 25, 2020Tutor
DaneA
