cwoodfield
Mar 21, 2023Aspirant
LACP link traffic levels on GS110EMX
I've got two ports on a 10-Gigabit/Multi-Gigabit Plus (GS110EMX) configured as a LACP LAG between the switch and my home broadband router, and I'm noticing that there's a huge difference in the trans...
- Mar 22, 2023
The GS110EMX is built on a non-managed core with some basic configuration controls, similar to the unmanaged GS110EM. The design is pure L2, so MAC based LAG only as you already noted. This design is not intended to provide to provide byte-exact load balancing at all.
schumaku
Mar 22, 2023Guru - Experienced User
