andreas_schmidt's avatar
Sep 27, 2024
LAG between stacked M4300 and Extreme Networks X590
Hello.
I want to create LAG between our 2 stacked M4300 and 2 switches X590 from extreme networks. The X590 are managed by the network admin of our university. He says, he has prepared 4 ports for lacp on his switches.
I also create LAG with 4 Ports, but i can not see any resoource on the other side. The port leds on bith sides show link and activity but  no echo from any ping to the other side.  I have tried all variants of options but nothing works. And the admin of uni "it's a problem of netgear".
I tried:
admin mode enabled/disabled
hashmode 1-6
stp mode enabled/disabled
static mode should be disabled
link trap enabled/disabled
If i use only one of the other ports on the X590 everything works fine with every port of my LAG.
What can I do?
Andreas
ProSupport for Business
