KHIng
Aug 06, 2025Aspirant
LAG with LACP GS752TXPv3 Windows Server
Hello,
I have a problem on a GS752TXPv3 with setting up a LAG with LACP for a Windows server (2-port Intel NIC) with NIC-teaming.
The Windows configuration ran stable for years on a GS752TXS without any change.
Teaming with LACP dynamic.
When I set up the LAG on the GS752TXPv3 and set it to LACP (source/destination MAC, incoming port), a broadcast storm starts when the server is plugged in and connectivity is restricted.
I can reproduce the issue with W2012R2 and W2022, Intel and Broadcom server-NICs, switch firmwares 6.2.1.32 and 6.2.2.15.
What am I doing wrong?
Best
Kai-Uwe
- KHIngAspirant
OK, I have now tried to connect the server to the switch with only one NIC port, without LACP, and a broadcast storm occurs in the same way, causing "Drop excess traffic"
However, other devices work perfectly on the switches.
What is going wrong?
I have uninstalled, restarted and reinstalled the network cards to reset the parameters.
And again: This is reproducible on two different switches of that type with different servers. - KHIngAspirant
I have now downgraded the firmware to 6.2.1.32. Now the connection works with one port without broadcaststorm, network detection works in the server.
In the LACP-LAG still Broadcaststorm.
