ubiq1er
Mar 12, 2021Tutor
Let's talk about switches and ping
Hi, Recently bought an additional GS108PEv3 switch to power up some Access Points. I accessed to its management interface to configure it (Static Ip, VLAN settings,...) After that, I put it whe...
schumaku
Mar 12, 2021Guru - Experienced User
L2.
Show us the VLAN and PVID config of all switch ports and the PC ports involved.
ubiq1er
Mar 13, 2021Tutor
Thank you for your answer.
Attached, you'll find 3 pictures to show you all the config.
I probably found the reason why PC B didn't answer to ping => ICMP was off in its Firewall settings; so, this point is not an issue anymore..
I still have no idea why I can't ping my 8 port switch, nor access to its management interface from afar (I must be directly plugged in one of its physical ports to do so).
I tried to access the management interface in VLAN ID 10, like illustrated on my attached picture; but I tried on VLAN ID 1 too, with other physical ports, thinking that VLAN ID 1 (default) was maybe the management VLAN (but after some reserach in this forum, there seems not to be such a VLAN on this model; management interface should be accessible through all VLANs).
I'm probably missing something trivial, but I just don't see it...
- ubiq1erMar 16, 2021Tutor
So, is the configuration of my VLANs ok ?
Still no access to my GS108PEv3 Management Interface switch, when I'm not directly plugged on it.
Where should I look next ?- ubiq1erMar 16, 2021Tutor
Ok, it was partially my fault.
I thought I had tried to access my switch through VLAN1, but had picked the wrong cable.
So to access my switchs web administration page, I have to :
- Put my PC on the same subnet as the static IP of my GS180PEv3 switch (of course)- Plug the cable of my PC directly in a physical port of my GS108PEv3 switch - In this case any port - any VLAN works.
- Plug the cable of my PC in any switch of my network, but in a physical port belonging to VLAN 1.
So VLAN1 seems to be default management VLAN for my GS108PEv3 switch, after all.
