trschell
Mar 01, 2021Follower
letter of volatility - GSS108EPP
Would you have a letter of volatility for the GSS108EPP? If that is not available, can you post the letter of volatility for the GS108 instead? Thanks!
schumaku
Mar 01, 2021Guru - Experienced User
GS108 is essentially remove power and use Windex.
More similar to the GSS108EPP would by any GS1xxE[xx] - here essentially factory reset is required.
PS. It's crazy what kind of administrative overhead have been caused by this LoV requirement.
