jpiemme's avatar
jpiemme
Follower
Mar 25, 2020
Letter of Volatility for GS716T
I would like to request a copy of the volatility report for the GS716T.
Thank you,
Josh
  • jpiemme,
    Welcome to the community! :)
    The latest model of the GS716T switch is GS716Tv3 (v = version).  You can download the Letter of Volatility of the GS716Tv3 on this link.  The link will expire after 2-3 days.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    jpiemme,
    DaneA
ProSupport for Business
