jkonz
Apr 26, 2017Aspirant
Letter of Volatility GSS108E
Hello, I am in need of a letter of volatility for a GSS108E. Please provide details.
Thanks
I just want to follow-up on this. Let us know if have further questions.
Otherwise, if ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
- jkonzAspirant
Thank you for the Certificate of Volatility.
Can you confirm that the only time the Flash is modified is when the switch is configured or updated with the flash programmer?
Thanks
- DaneANETGEAR Employee Retired
I inquired your concern to a higher tier of NETGEAR Support and I apologize for it took some time. I just got feedback just now.
Question: "Can you confirm that the only time the Flash is modified is when the switch is configured or updated with the flash programmer?"
Answer: No, the flash stores the firmware and the config file, therefore anytime a new firmware image is uploaded or there is a change to the config file the contents on the flash are modified.
DaneA
