ofuen
Oct 30, 2018Aspirant
Letter of Volatility Request - GS516T
Hello all,
I am trying to acquire a letter of volatility for the PROSAFE model GS516T 16 port switch. I noticed under the model drop down menu only went up to the GS504 but I was able to find a ma...
- Oct 31, 2018Thank you. The response from this community forum is awesome.
JohnC_V
Oct 30, 2018NETGEAR Employee Retired
Hi ofuen,
Welcome to our community! :)
Here is the letter of volatility for GS516T. No password needed and the link will expire after 48 hour period.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ofuen
Nov 14, 2018Aspirant
Good Morning,
First thank for response on LOV for the GS516T. I noticed that the LOV stated the there was no memory. Is there no non-volatile firmware in this product? My security officer is pretty sure it does. Any specification sheets available other documents available?
Thanks
Orlando
- JohnC_VNov 14, 2018NETGEAR Employee Retired
I may need to inquire the lists of all the switches that has a memory. I'll get back to you once I got the information. But, definitely these type of switches doesn't have any memory or even a non-volatile firmware.
- ofuenDec 06, 2018AspirantJohnCarlovV, Just touching base to see if this is still on your radar? Orlando
