ofuen
Oct 30, 2018Aspirant
Letter of Volatility Request - GS516T
Hello all,
I am trying to acquire a letter of volatility for the PROSAFE model GS516T 16 port switch. I noticed under the model drop down menu only went up to the GS504 but I was able to find a ma...
- Oct 31, 2018Thank you. The response from this community forum is awesome.
ofuen
Nov 14, 2018Aspirant
Good Morning,
First thank for response on LOV for the GS516T. I noticed that the LOV stated the there was no memory. Is there no non-volatile firmware in this product? My security officer is pretty sure it does. Any specification sheets available other documents available?
Thanks
Orlando
JohnC_V
Nov 14, 2018NETGEAR Employee Retired
I may need to inquire the lists of all the switches that has a memory. I'll get back to you once I got the information. But, definitely these type of switches doesn't have any memory or even a non-volatile firmware.
- ofuenDec 06, 2018AspirantJohnCarlovV, Just touching base to see if this is still on your radar? Orlando
