RyanStauss's avatar
RyanStauss
Letter of Volatility
I'm sorry I know this has been asked dozens of times before, but I cannot find a working link.  They all have expired.  Please may I have a working link to download a copy of the Letter of Volatility / Statement of Volatility.
Thanks
  • RyanStauss,
    Welcome to the community! :)
    Since you have indicated the GS724T, be reminded that the latest version of the GS724T switch is the GS724Tv4.
    You can download the Letter of Volatility of the GS724Tv4 on this link.  The link will expire within 2-3 days.
    If you were able to download it and do not have any further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    RyanStauss,
    DaneA
    • DaneA's avatar
      DaneA
      RyanStauss,
      You're welcome! :)  Kindly mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
      DaneA
ProSupport for Business
