OlafE's avatar
OlafE
Tutor
May 09, 2019
Memory log flooded on stacked S3300-52X ProSAFE 48-Port Gigabit Stackable Smart Switch
Hello, the memory log is flooded every two seconds with the same message: BSP[unitMgrTask]: bspcpu_i2c.c(1595) 21619 %% Unable to Read BSC controller offse...
  • OlafE's avatar
    Jun 06, 2019
    With the help of Netgear support could be determined, that the error messages seemed to be related to one of the SFP ports of one of the switches (without further details, which switch or which port). Since these ports where involved in the stacks ring topology I found that two ports of the SFP ports did show offline.
    After I could someone onsite to check/replace the cable, the missing ports flashed online and the error message disappeard. So we had basically a broken ring with a less than sufficient error message tied to this.
    Best greetings from Germany
    Olaf
ProSupport for Business
