ARNETEX
Apr 28, 2022Follower
More DHCP Woes on VLANs
 I'm stumped, I just took over an environment that has GS752TP Switches deployed.  One in the main building where server room is and then 3 more in fiber connected buildings across the campus.  It was...
JohnC_V
May 12, 2022NETGEAR Employee Retired
Hi ARNETEX,
Welcome to our community! 🙂
It seems that you are having issues with the setup of your network. You should assign the uplink port as Tagged so that the DHCP from the data and voice VLAN will pass through. You should assign the phones also as Tagged and assign the PVID of those ports to the data VLAN.
e.g.
VLAN 240
Phone 1 - Port 5 - T
PVID 200
John
NETGEAR Community Team
