kc6108
May 14, 2019Luminary
MS510TX - Link Traps
I am in need of some guidance, once again, please.
I am used to Netgear Smart Managed Pro switches having the option to turn on Link Traps at the PORT/LAG level under Switching -> Ports -> Port...
- May 14, 2019
Aehm, no - the MS510TX online help does mainly mention "the number of traps" for the Trap Logs. Granted, a little bit misleading.
schumaku
May 14, 2019Guru - Experienced User
Monitoring -> Ports -> Port detailed statistics does show "Link Trap Enabled" for all ports, FWIW
kc6108
That is what I am seeing as well... Link Trap is showing as Enabled on all ports on the Monitoring -> Ports -> Port Detailed Statistics screen.
I must be missing a setting somewhere?
