Jacko-UK
Sep 05, 2022Aspirant
MS510TX Multi-Gig Switch - Speed Issue
MS510TX Multi-Gig Switch - Speed Issue Hello all - I wonder if someone would be kind enough to offer me some help. I have owned an MS510TX Multi-Gig switch for a couple of years (it's running th...
DaneA
Sep 07, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
What is the current firmware version of your MS510TX? If ever its not yet the latest version, I suggest you to update it then check if the same problem will occur.
The latest MS510TX firmware is v6.7.0.52 and you can download it here.
DaneA
NETGEAR Community Team
- DaneASep 07, 2022NETGEAR Employee Retired
My bad! 😞
Are there VLANs configured on the MS510TX? Or is the MS510TX being used like an unmanaged switch?
If the MS510TXis being used just like an unmanaged switch, let us try to perform a factory reset then check if the same problem will occur.
If ever there are settings configured on the MS510TX, I suggest you to back up the settings before doing a factory reset. After doing a factory reset, restore back the settings then check if the same problem will occur.
If still the same problem occurred, I suggest you to open a support ticket with NETGEAR Support here at anytime for further investigation.
DaneA
- Jacko-UKSep 09, 2022Aspirant
DaneA No worries mate! 😉 Thanks for your help - it's appreciated.
There are no VLAN's configured, it's just being used as an unmanaged switch.I tried the factory reset, then reconfigured. Unfortunately the speed issue was not resolved. I will open a ticket with support.
