Jacko-UK
Sep 05, 2022Aspirant
MS510TX Multi-Gig Switch - Speed Issue
MS510TX Multi-Gig Switch - Speed Issue Hello all - I wonder if someone would be kind enough to offer me some help. I have owned an MS510TX Multi-Gig switch for a couple of years (it's running th...
DaneA
Sep 07, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
What is the current firmware version of your MS510TX? If ever its not yet the latest version, I suggest you to update it then check if the same problem will occur.
The latest MS510TX firmware is v6.7.0.52 and you can download it here.
DaneA
NETGEAR Community Team
