MasterMechTech
Jan 17, 2022Tutor
Netgear GS108Ev3 Switch Bricked?
Just purchased a GS108Ev3 & have installed it but I cannot get it to respond no matter what I try. The power light is illuminated & solid but the switch is not detected on my network. I have ...
- Jan 18, 2022
Depending on your market, get a replacement from your reseller or distributor (standard outside of NA, typically easier and faster), or head to https://my.netgear.com/, register the switch if not done it already, click on the entry, and follow the [Request a Hardware Replacement] process.
schumaku
Jan 18, 2022Guru - Experienced User
- MasterMechTechJan 18, 2022Tutor
Thanks for the advice, Amazon are sending a replacement out.
- Apr 12, 2023Retired_Member
