Cadsy
Apr 12, 2019Aspirant
Netgear GS110TP - Port Mirroring
I have been asked to configure port mirroring on this switch for Call recording on a hosted telephone system. My IT knowledge is limited so please be gentle.
I have a port on the Broadband/Phone ro...
- Apr 12, 2019
Hi Schumaku,
Thanks for your reply. I am not planning to use G2 for mirroring. That was programmed by trial which I cant delete now. I plan to only mirror G1 to G7
all voice traffic goes through G1 so if i mirror this to G7 (Which is the call recorder) then i should be ok? The customer only has 5 phones so i dont think if all phones were in use then this would be an issue.
Cadsy
Hi Schumaku,
schumaku
Apr 12, 2019Guru - Experienced User
Just mark the second entry on the left, and use [Delete] should get rid of the entry.AS long this is not enabled, that won't hurt. And no worries, VoIP is not very bandwidth intensive.
