clarke_gavin
Jan 09, 2021Aspirant
Netgear GS116ev2 - IP Conflict
Hi, I have the following setup Virginmedia SuperHub 3.0 in Modem Mode -> TP Link Archer C80 Router -> Netgear GS116Ev2 Switch -> Various devices I'm experiencing multiple issues (wired & wi...
- Jan 18, 2021
Turns out it was a rogue DHCP server in my Horizon set top box that was wired to my router, causing IP conflicts. Once I disconnected the set top box from the router (this was how Virgin Media originally set it up, which I had emulated on the new router), the problems disappeared!
schumaku
Jan 09, 2021Guru - Experienced User
There is nothing on these switches what can impact L3, including the DHCP part.
Unless the switch is massively broken or malfunctioning - what is unlikely - it can't impact the complete network that heavily, certainly not on it's own.
Can't see any indication of an IP conflict in the problem description. Decent computers will fall-back to zero config addresses (169.254.x.x) if the DHCP process fails.
- clarke_gavinJan 18, 2021Aspirant
