Harmmiee
Jan 21, 2021Aspirant
netgear GS324TP V1 login
Hello everyone! My network is wierdly conected and stuff. but I want to acces my network switch via ip adress. But i cant find the ip adress. I have looked in my orbilogin.com, and even my modem...
CrimpOn
Jan 21, 2021Guru - Experienced User
Harmmiee wrote:My network is wierdly conected and stuff. but I want to acces my network switch via ip adress. But i cant find the ip adress. I have looked in my orbilogin.com, and even my modems admin page.
The switch User Manual describes how to find the IP of the switch on page 12:
Harmmiee wrote:And also I think its wierd that the modem and router are diferent like 192.168.1.? and 192.168.2.?
Because the Orbi is a router, it has created an IP subnet for its Local Area Network (LAN) that is different from the network on the Wide Area Network (WAN) side. I suspect that the modem may be a combination modem/router, which can be verified by checking the WAN IP address using the Orbi web interface, (a) on the Basic Tab, select the "Internet" menu, (b) on the Advanced Tab, it appears in the "Internet Port" box. If it is a Private IP address, then the modem is for certain a modem/router.
https://en.wikipedia.org/wiki/Private_network
If the Orbi is connected to a router, then Port Forwarding cannot be done until one of them is "not a router".
Harmmiee
Jan 25, 2021Aspirant
Oke thanks.
How can I turn my modem/router combination just so it will be a modem. Becouse the TV has to be plugged in the modem/router thing.
- vajimJan 25, 2021Master
Harmmiee wrote:
Oke thanks.
How can I turn my modem/router combination just so it will be a modem. Becouse the TV has to be plugged in the modem/router thing.Here's how to set the orbo to ap or router mode
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
you may have to call the folks who gave you that modem
- HarmmieeJan 25, 2021AspirantAlright, so if I put the orbi in AP mode it will have the same network as the modem?
So then internet and wifi will still be the same network?
