Harmmiee
Jan 21, 2021Aspirant
netgear GS324TP V1 login
Hello everyone! My network is wierdly conected and stuff. but I want to acces my network switch via ip adress. But i cant find the ip adress. I have looked in my orbilogin.com, and even my modem...
Harmmiee
Jan 25, 2021Aspirant
Oke thanks.
How can I turn my modem/router combination just so it will be a modem. Becouse the TV has to be plugged in the modem/router thing.
vajim
Jan 25, 2021Master
Harmmiee wrote:
Oke thanks.
Here's how to set the orbo to ap or router mode
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
you may have to call the folks who gave you that modem
- HarmmieeJan 25, 2021AspirantAlright, so if I put the orbi in AP mode it will have the same network as the modem?
So then internet and wifi will still be the same network?- vajimJan 25, 2021Master
So then internet and wifi will still be the same network?yes & yes
- HarmmieeMar 18, 2021Aspirant
Well... I put the orbi in AP mode, and put the switch in the modem/router combi thing...
But now I dont have cabled internet. only the wireless network form both the orbi and modem/router works.
So its not both the same network i guess. becouse in the wifi settings there are 2 networkes now...
I also tried doing it so the switch is in the orbi and the orbi connected to the modem/router combi thing...
anyone has any ideas?
edit: The 192.168.2.? is now all 192.168.2.? so that is fixed. but now I dont have cabled internet connection...
ooh, and the pc that is conected via internet cable true a orbi satelite has internet.
