tantony
May 22, 2019Luminary
Netgear GS716Tv3 delete VLAN 2 and 3
I'm using VLANs 2,3,4 on my network. I just got a new GS716Tv3, and I noticed that there's already a Auto VoIP VLAN 2, and Auto -Video VLAN 3. How can I remove them? I changed the Auto VoIP VL...
- May 24, 2019
Hi tantony,
Unfortunately, we cannot delete the VLAN 2 and 3 on this type of switches as it is installed by default. You may need to use other VLAN IDs instead.
JohnCarloV
NETGEAR Community Team
tantony
May 24, 2019Luminary
You're correct. I called Netgear support, and I had them remote in, and they couldn't delete it either. I have to have those VLANs because I have them in my network already. I also have 2 GS308T, and it came with a default VLAN 2, and I was able to modify it. I'm returning the 716Tv3, and ordering a GS324T
I don't understand why Netgear won't let me delete anything but VLAN 1. Shouldn't I have control of how my network is designed?
JohnC_V
May 24, 2019NETGEAR Employee Retired
Thank you for bringing this up. I believe these are only the type of switches that can't be modified on VLAN as, by default, VoIP is always assigned as VLAN 2.
We do apologize for the inconvenience this may have caused you.
JohnCarloV
- Aug 04, 2022Retired_Member
- Sep 11, 2016Retired_Member
- Sep 24, 2021Retired_Member
