mjkalba's avatar
mjkalba
Netgear GS748Tv4 Device View
I have recently acquired a second-hand GS748Tv4 switch for use in my home network. Everything is working fine, with one exception. When I select System | Device View, I get a message that I need the Java plugin. Unfortunately the Java plugin is no longer by supported by any the browsers I have tried - Firefox, Chrome, Opera, Edge. Does anyone know of either a solution, a browser that will work, or a workaround that will allow me to access the Device View?
  • schumaku's avatar
    schumaku
    No workarounds, no hacks.
    Nothing very useful or essential on the device view on my opinion.
    • mjkalba's avatar
      mjkalba
      Thanks. I won’t actively pursue it. As long as it is working I can live with it.
ProSupport for Business
