syedzaidi110's avatar
syedzaidi110
Netgear Lead times
Hi, I am looking at Netgear MS510TXPP-100EUS for a small setup at different sites which may include bulks of these switches, however, this switch is pretty much out of stock at every retailer. Can anyone confirm the lead times on these, if availble? and whether they're close to EOL.
A swift response would be appreciated.
  • ah okay i'll try and look for the EOL, can you try and hook me up with the replacement model code?
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    syedzaidi110,
    Welcome to the community! 🙂
    The MS510TXPP switch is already EoL (End of Life).  As reference, kindly check page 19 of NETGEAR End of Life devices here.
    Since the MS510TXPP switch is already EoL, you may want to check the MS510TXM and MS510TXUP switch models.  To learn more about the MS510TXM and MS510TXUP switch models, check the data sheet here.
    DaneA
    NETGEAR Community Team
ProSupport for Business
