Siju
Dec 25, 2021Aspirant
Netgear Switch web changes immediately applied without apply button
I'm quite surprised how Netgear could release a software (latest firmware) that applies a network change immediately after you type or select an option without waiting for the apply button to be touc...
michaelkenward
Dec 26, 2021Guru - Experienced User
Siju wrote:
I'm quite surprised how Netgear could release a software (latest firmware) that applies a network change immediately after you type or select an option without waiting for the apply button to be touched.
Is this on the GS308E Ethernet Smart Managed Plus Switch listed in your footer?
Many problems apply to a swath of devices. One router is much like another in many aspects. So questions about General WiFi Routers (Non-Nighthawk and Non-Orbi), the topic of this section, could apply to most routers, but switches and routers don't share many features.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Smart / Plus / Click Switches - NETGEAR Communities
or
Discuss Ethernet Switches Plus and Pro Managed
This might also be useful:
Search - NETGEAR Communities – GS308E
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
