Siju
Dec 25, 2021Aspirant
Netgear Switch web changes immediately applied without apply button
I'm quite surprised how Netgear could release a software (latest firmware) that applies a network change immediately after you type or select an option without waiting for the apply button to be touc...
schumaku
Dec 27, 2021Guru - Experienced User
Siju wrote:
...that applies a network change immediately after you type or select an option without waiting for the apply button to be touched. It is almost impossible to make changes because the software goes ahead and applies that half baked change.
Please provide some more details, the exact use case, or config process where this immediate change does leave the switch or config in a half baked config state.
Version number?
Has this changed or became worse since which version?
